2004 climate control center
Old Oct 3, 2011 | 02:27 PM
jsa750k's Avatar
The a/c worked fine yesterday ,today it blows hot air. Wont take any 134,when I attach the re-charge hose it shows 150 lbs. Then I go to turn on the a/c and the screen is all lit up but I have nothing working,no fan,temp,nothing... Any help ?
Old Oct 3, 2011 | 03:10 PM
Before you started trying to recharge it was the blend door checked for correct operation?
Old Oct 3, 2011 | 04:29 PM
jsa750k's Avatar
Thanks for the reply ! No,I just assumed refrig. was low. Like I said,it all worked fine the day before,then nothing. Compressor doesn't come on . Now the the nscreen shows all lights,def,fan,heat,etc... but nothing works at all
Old Oct 3, 2011 | 04:31 PM
jsa750k's Avatar
how do I check the door ?
Old Oct 3, 2011 | 04:34 PM
Might have a problem there......if all the lights are lit up ........
Check the fuses and connections....
Blend door video>>>> http://www.youtube.com/watch?v=0di2RDA9iTA
Also try taking the eatc /climate controller and unplugging it and plug it back in.....see if that resets it.
Old Oct 10, 2011 | 10:18 AM
jsa750k's Avatar
I replaced the relays first,then my wife had the truck for 4 days,it reset itself ! Everything back to normal ! Weird
