07 F150 Electronic Temp Control Problem
Old Apr 8, 2011 | 02:43 PM
eb02z06's Avatar
I have an 07 F150 Lariat with the electronic temp control. Problem I'm having that when I set a temp level like say 24 degrees( canadian temps-lol ), the temp will get too hot, then when I lower it, it will get too cold.
There's no happy medium and get's annoying on long drives. Does anyone else have this issue-is there any fix?
TIA.
Old Apr 8, 2011 | 10:58 PM
sam1947's Avatar
Sounds like it could be the blend door actuator motor, common problem....fairly easy fix, around $35.00 for the part and about an hours time to replace
Old Apr 9, 2011 | 10:49 AM
Windsor's Avatar
Yep, check out TSB 08-23-6. It should be covered under warranty. Very common issue in 2007s and 2008s.
Old Apr 10, 2011 | 01:43 AM
eb02z06's Avatar
Thanks guys-what do? Call the dealer and tell them the problem and the TSB?
Old Apr 10, 2011 | 09:48 AM
Windsor's Avatar
That's where I'd start. I ended up picking up the part and replacing it myself. I haven't had great luck with warranty work. With my last truck they were either not putting things back on properly or breaking something else in the process.
