vents blow air when off
Sometimes the HVAC vents on the dash of my truck will just randomly start blowing air out even when the right **** is in the off position. Its always only the dash vents and never the floor or defroster vents.
The speed of the air depends on which number the left **** is turned to and the air is warm or cool depending on where the center **** is turned to. I can turn the blower speed up or down and it changes the speed like it should if the vents were actually on.
Lately it seems that sometimes when I turn the position switch to the floor heat position nothing happens for a bit and then heat will come out.
Its sometimes getting harder to stop the vents from blowing air when its supposed to be off.
I would like to know what is causing this to happen because its rather annoying and Id like to stop it from happening.
Could the switch panel be at fault?
