Automatic Climate Control
Old Oct 5, 2002 | 01:43 AM
turbo497's Avatar
been working on wiring for EATC swap and need to know if the harness is modular construction If there are any ford Techs out there please look at what I have come up with so far and give me some feed back on harness.
First
I cross referanced with 2000 expedtion harness and wonder if anyone can get part numbers for the following causal harness numbers 18b518 and 14401
second looks like truck will have to be refitted with
(1)blower speed controller to replace resister type.(c282)
(2)need new blend door actuator
(3) need sunlight sensor
(4) need in car temp sensor and maybe new radio dash surround to house it
(5) my truck already has ambient temp sensor just have to pick up sensor from harness
ETAC connector conversion Rough draft! INFORMATIONAL ONLY
CODE
-> TO
<-FROM
* EXISTING NO EATC CONNECTOR
? DID NOT FINISH TRACE YET( YOUR INPUT WELCOME)
THREE DIGIT NUMBER ARE CKT NUMBERS
: MEANS CKT DISCRIPTION
GOES IN THIS ORDER
pin/CRKT/WIRE CODE/DISC
CONNECTOR C280 ON EATC
1-915 PK/BL:SBC- ?
2-729-RD/WH:POWER HOT ALL TIMES
3-57-BK:GROUND <-*C219 PIN 1
4-470- SENSOR INPUT GROUND ?
5-n/a
6-243-LG/OG: BLEND DOOR ACT FEEDBACK +5 -> C229 PIN 5
7-767 LB/OG: AMBIENT SENSOR INPUT
15-914-TN/OG:SPC+ ?
16-296-WH/VT: POWER HOT IN RUN ?
17-461- OG :BLOWER RELAY ?
18-246-VT: BLEND FEEDBACK WIPER ->C229 PIN 1
19-434-LB/BL:FRONT PANEL ILLUMINATION <-*C219 PIN PIN 2
20-468-BN-:SUNLOAD SENSOR INPUT
CONNECTOR C281
8-1070-BN/LB :STEERING WHEEL INPUT (NOT YET)
9-247-WH/YE:BLEND DOOR ACTUTOR FEEDBACK GND ->C229 PIN6
10 N/A
11-348-VT:A/C CONPRESSOR CUTOFF -> *C217 PIN 3
12 N/A
13-250-DG:BLEND DOOR ACT MOTOR DRIVE HEAT ->C229 PIN 7
14-19-LB/RD:INSTRMENT PANEL LIGHT FEED ?
21-790- WH/OG: IN CAR TEMP SENSOR INPUT
22-575-YE/BK: RELAY TO AUX CONTROL(DUAL ZONE) N/A
23-184-TN/OG: BLOWER CONTROL INPUT ->C282 PIN 3
24 N/A
25 n/A
26-DB/LG:BLEND DOOR ACTUATOR DRIVE COOL -> C229 PIN 8
my theory is that if the harness is of modular design I can swap out the harness at one of the in line connector faces to come up with the proper harness connectors to the newly installed modules
Old Jan 30, 2004 | 09:54 PM
SteveB's Avatar
Does anyone have any updates (or a how-to maybe)?
Old Feb 1, 2004 | 11:19 AM
Reloader's Avatar
Since auto climate control was offered as standard equipment on the '03 Screw Lariat, you could check the
Ford parts catalog for the part numbers that you would need. Since I'm not a hvac expert, I wouldn't be able to
tell you what actual parts you would need for a conversion.
But it would be a good place to start.
Old Feb 9, 2004 | 01:08 AM
sid297's Avatar
This may help:
http://www.generation-edge.com/forum...TOPIC_ID=15223
