hvac resistor
Old Aug 7, 2010 | 09:19 PM
03heritage150's Avatar
Question hvac resistor
if your blower control works all speeds but for med. high, and you change the resistor will this correct the problem?
Old Aug 7, 2010 | 09:39 PM
OhioTC18's Avatar
Are you saying it does not work on High?
Usually the resistor is bypassed for High speed. The lower speeds not working could be a resistor problem.
Old Aug 7, 2010 | 10:44 PM
ELVATO's Avatar
When you say med. high, you saying the Medium High (the one with the red arrow in the picture), or are you saying medium and high speeds are not working?
If you meant medium high, then yea, I'd guess the resistor is bad.
Old Aug 8, 2010 | 04:24 PM
yes I ment the 1, 2 & 4th positions work, but the 3rd does not.
Old Aug 8, 2010 | 08:33 PM
OhioTC18's Avatar
It could be the resistor then.
Old Jan 7, 2013 | 12:21 PM
Ed222's Avatar
05 resistor pack location
I have no heat on settings 1&2 I figure this is the resistor pack but I can not locate it on my truck. 2005 F-150 i was looking behind the glove box but im not sure where. Help
