Replaced Blower Motor Resistor; problem still exists ('06 XLT)
Old Feb 1, 2010 | 07:03 PM
jasonsbytes's Avatar
I replaced my resistor and the problem is still the same:
speed 1 works
speed 2 works
speed 3 (stays the same as 2)
speed 4 works
I searched multiple other threads about the problem but it seems replacing the resistor worked for everyone else.
Any thoughts, what else could it be?
Old Feb 17, 2010 | 10:32 AM
markwt's Avatar
Same issue
I have a similar issue, 1,2,3 do not work but 4 does. I replaced the whole panel with the selector switches and that did not solve the problem. Did you ever find out what your problem was?
Old Feb 17, 2010 | 10:35 AM
well, if 1,2,3 do not work and 4 does it's almost 100% certain that it's the resistor. You can get that from autozone or a dealership around $20, drop the glove box down, unplug it, remove 2 screws and you're done.
Old Feb 26, 2010 | 11:32 AM
Replaced my switch and it works fine now.
