fan only works on 2 settings
Old Jan 21, 2010 | 03:33 PM
tbones's Avatar
Originally Posted by ford norseman
I spent a few years as a mopar dealer mechanic, and this problem was common on the caravans. If the resistor was replaced and then went bad a few weeks later, it was always the blower motor causing the problem. If the blower motor is drawing too much current it will burn out the resistor repeatedly.
Obviously your truck is not a caravan, but the setup for these hvac systems is all pretty similar. Just my two cents, hope it helps.
Finally figured out how to get the motor out. It was pretty rusted. Didn't move freely if you spin slow. Replaced motor and resistor. Back in business.
Old Jan 21, 2010 | 07:26 PM
ford norseman's Avatar
Happy I could help!
Old Jan 22, 2010 | 11:35 AM
jasonsbytes's Avatar
I just ordered the resistor from Autozon for $16.
1 - nothing
2 & 3 - same as 2
4 - works like 4
Old Feb 1, 2010 | 06:37 PM
Well, I replaced my resistor and the problem is still the same:
speed 1 works
speed 2 works
speed 3 (stays the same as 2)
speed 4 works
any thoughts?
Old Feb 1, 2010 | 07:27 PM
Zaairman's Avatar
speed 1 works
speed 2 works
speed 4 works
any thoughts?
Try a new switch.
Old Feb 1, 2010 | 08:14 PM
Yep; I did some more searching and a new switch is next on the list. Any tips on replacing that?
Old Feb 26, 2010 | 11:33 AM
replaced the switch and that fixed it.
Old Mar 21, 2010 | 01:13 AM
madmike232's Avatar
hey all i am new to this site and this is my first post how hard is it to change the blower moter on a 01 Screw? and i think i need the resestor to only working in high
