HVAC Issues
Old Jan 30, 2009 | 04:12 PM
dclydep's Avatar
HVAC Issues
My AC works fine, blows from the front panel and gets cold. Heat on the other hand is an issue. No matter what setting (floor, floor/def, def, front panel) no heat blows as it should. The cab gets warm as the heat does come on, but it does not come through the vents. I am hoping someone can point me in the right direction before I take it to be looked at.
Thanks.
Old Feb 2, 2009 | 11:37 AM
jayjaysin's Avatar
Read all of the other posts on HVAC issues. If you have Electronic Auto Temp Control and you're still under warranty, there is a service bulletin issued and they will fix it.
