Got a question about my HVAC
Old Jul 28, 2008 | 09:07 AM
Mon150tana's Avatar
Howdy all I'm new to the forum , but have been crawling on F150online for a while now. Seeing as its finally warm enough up here in Montana (just cracked 65) I recently switched from "defrost" to "Max AC" and what I noticed is that the air still blew out only on the defrost vents up by the windshield. Knowing that this isn't normal, I was wondering if there was some way to fix this. Any ideas? Its a 2001 Screw 5.4L.
Old Jul 28, 2008 | 09:27 AM
projectSHO89's Avatar
It's a really common issue.
Click on SEARCH and enter "+defrost + vacuum" for previous discussions.
Steve
Old Aug 3, 2008 | 03:51 PM
Bill C.'s Avatar
Check your vacuum pump. Look at the HVAC problem thread above.
Old Aug 4, 2008 | 08:44 AM
Any truck with a gas engine doesn't have a vacuum pump. Those are only needed on diesels.
Steve
Old Aug 5, 2008 | 05:51 PM
IR0NS1N's Avatar
I believe on the Fords (01 etc) the mode door was actuated by vaccum. I would check for a broke vac line near the firewall, its usually a brighter color like yellow or orange and will go through the firewall at some point.
I havent worked on to many fords (being they are of a better quality) so Im guess its vaccum operated.
