Temp control switch
Old Jan 8, 2008 | 01:47 PM
Justfishing's Avatar
Temp control switch
How do I check the temp control switch on a 98 f150 - manual heat. There are 3 prongs on the back. What test can I do to confirm is not the switch.
Old Jan 8, 2008 | 05:25 PM
projectSHO89's Avatar
What are you trying to confirm (or not)? That it is a temperature control?
It's just a potentiometer.
Old Jan 9, 2008 | 11:01 AM
I got out the mutlimeter this moring. There are 3 prongs. No matter the dial position the meter reading is the same. I assume the center 1 is the hot connection and the outer ones control the door depending on voltage.
