05 F150 SCREW intermittent poor chillin
Sometimes when I start the truck it blows warm with the A/C on. Probably low pressure, I'd guess. How can I test the switch? If I switch off the A/C or the engine and then turn the A/C back on it cools. Weird, huh?
So, I have taken to starting the truck and then starting the A/C, which works but makes me wonder.
I'm thinking of having an evcuation & recharge to see if it has a low charge, the shop I used to work at can measure what they pull out and replace for me. Am I overdoing this? Or am I saving my compressor from running without enough lubrication which is what happens with low rfrigerant charges.
I am a tool and chemical rep, we sell A/C tune up kits which give a 4 oz hit of R134, some A/C dye and a little oil. I'm leery to do this because when I worked in the desert the A/C guys always drilled us to use exact quantities. Any real A/C experts on here?
