Blend door blunders
Old Nov 4, 2006 | 01:12 AM
Deltacotton12's Avatar
Blend door blunders
, i replaced my heater core, and after replacing the whole dash, i realized the blend door was stuck on heat. so i replaced the blend door motor and it still is stuck on heat. so i then repaced the switch and STILL NO blend door action.. i'm stuck now. i figured it was one or the other.. any other problems or thought similiar to mine?
Old Nov 4, 2006 | 01:50 AM
ExPartsMan's Avatar
Vacuum leak...check the ends of the hoses..might be cracked. Otherwise leak could be anywhere.
And new motor/switch could be defective...wouldn't be the first time this happened.
Old Nov 5, 2006 | 04:47 PM
well, i guess that system needed time to recognize the new part?? cause i woke up this morning and everything is working properly.. the heater core is pushing out heat and the blend door is doing its thing correctly... so this is a happy ending.. thanks for the post.. i do know that i have a vaccuum leak in the system. during acceleration i loose the air flow to the defrost. i'm still trying to track down this problom...
