Where are the vent vaccuum lines ??
Old Oct 23, 2006 | 08:38 AM
snkbtn99's Avatar
I have a 2004 FX4 SC and am having issues with getting the vents to change position. They are permanently stuck in the front vent position. I cannot get them to change to the floor or the defrost selection.
Anyone have a pic or description on where the lines are located so I can check them? Thanks!
Old Oct 23, 2006 | 12:25 PM
snkbtn99's Avatar
Can anyone shoot me a quick picture of what these vacuum lines look like?
I just need to know what I am looking for ..... I do not see anything behind the battery like said in most threads.
Old Nov 2, 2011 | 11:40 AM
Quadkeys's Avatar
I have the same problem with mine stuck blowing on front windshield. Did you get this issue resolved, if so can you share.
Old Nov 2, 2011 | 03:17 PM
54regcab's Avatar
I think they are all electrical servos on the 2004+ models (no vacuum lines like the older models had). Blend door servo bad?
Old Dec 24, 2011 | 10:19 PM
Yankee7985's Avatar
Your vacuum line is on the right side of the engine compartment along the fender. It should be a black plastic line that is most likely cracked.
