A/C Not Blowing Cold
Old Oct 22, 2006 | 10:08 PM
mbruno's Avatar
Hello.
I just purchased a 1998 F-150 with only 95,000KMs on it. The air conditioner does not blow cold. The compressor cycles on and off, but the temperature of the air is no colder than the ambient temperature. Does the A/C system just need to be charged, or can something else cause this problem?
Thank you
Old Oct 23, 2006 | 03:03 AM
chrism9232's Avatar
hook up to and see i bet is is lowif the compressor comes on i bet all it need is one can about $8 just be glad it is r134a and not r12 or it can be your blenddoor
Old Oct 24, 2006 | 01:20 AM
BLUE20004X4's Avatar
How often does the compressor cycle, say on 3 seconds off 5 or something? Try to see if the temp setting changes with say vent on makes an air temp difference. When my blendor went, it was stuck on full heat. You sound down on refrigerant, r-134a.
Old Oct 24, 2006 | 01:57 AM
AC shouldnt blow cold, it should remove the heat.
also be sure to use virgin r134 and not r134 with the stop leak, or other additives.
-Patrick
Old Oct 24, 2006 | 07:33 PM
mbruno's Avatar
Blend door?
How would one go about checking if the blend door is the cause?
