99 F150 blows thru defroster under acceleration
My '99 F150 (5.4, auto, 4x4) began acting a little strange the last few weeks in reference to the title of this topic. Today I found what I thought to be the problem. There is a series of small vacuum lines to the rear of the battery. The one leading through the firewall was broken. It looked like it rubbed on the neg. battery cable clamp. I spliced it with a piece of new hose and some duct tape, (I know, I know :o ), for now.
Problem is that under medium to heavy acceleration the air switches by itself to the defroster, regardless of what I have selected. (Another example is when I'm climbing a semi-steep grade.) Before I found the broken vacuum line, I could only get air through the defrost vents. I don't know if my repair isn't sealed properly or if there is a bigger problem lurking under the dash. I've searched through many posts over the past few days and cannot find an answer to this problem for my year vehicle.
I do plan on replacing the broken line, just need a part number or a name to give to Ford.
Any help would be appreciated.
Thanks in advance!
Thanks in advance!
It's a vacuum leak.
I just went through this with my '97 Expy. One of the nipples was busted off the manifold located between the firewall and the battery. Fortunately I had enough of the nipple left where I could make up and ziptie the hose back on.
My problem is that the vacuum line actually broke in half, more liked sawed in half, about 3-4 inches below the connector. I think the only way to fix it is to replace the entire line. Just don't know how to get to it inside the cab.
I picked up some 7/32 (I think) vacuum line and spliced it back together. I did get the Ford part # also, if anyone is interested. The repair seems to be working so far. We'll see in a few hours while I drive through the mountains from San Diego to Tucson.
