Heater Core Clog?
Old Nov 30, 2004 | 11:08 PM
WildWilly's Avatar
Heater Core Clog?
Is there a way to tell if my heater core is clogged up? Bother heater hoses are hot, but no heat coming in to cab. Only COLD air. I was told that my core might be clogged. Should I get a radiator flush done on it or ?? Any imput will help
Old Dec 1, 2004 | 06:42 AM
fordracing19's Avatar
blend door is not working correctly most likely. Actuator bad?
Old Dec 1, 2004 | 05:53 PM
WildWilly's Avatar
ok, but is there a way to see if it's clogged. Blend door is fine.
Old Dec 1, 2004 | 08:41 PM
FloppyJoe's Avatar
if both hoses are hot, it's not clogged. how do you know the blend door is good?
Old Dec 2, 2004 | 07:34 AM
WildWilly's Avatar
Originally posted by Band_Aid
Yes both heater lines will be hot even if core is plugged. If you find that to be the case? You can take your lines loose and clamp your hose pipe on to it and blow it out. If that is the problem? After you blow it out you need to do a system flush and add fresh antifreeze.
Old Dec 2, 2004 | 11:34 AM
take the lines loose and see if water will flow through it. run the water hose with it on low.
Old Dec 2, 2004 | 12:47 PM
WildWilly's Avatar
Thanks, will do
Old Dec 2, 2004 | 12:49 PM
FloppyJoe's Avatar
I don't see how the return line could be hot if it was clogged. I guess maybe it's a partial clog
This question still remains:
This was the problem on mine when I was experiencing the same problem as you
Old Dec 2, 2004 | 05:25 PM
WildWilly's Avatar
THey said maybe the blend door motor is bad
Old Dec 3, 2004 | 01:59 AM
FloppyJoe's Avatar
mine just had loose wires. If you take that black panel off down there you can see where the wires plug in. If i held mine all the way to the right it would work okay.
Old Dec 3, 2004 | 07:32 AM
WildWilly's Avatar
Ok. I'm gonna tear in to it tomorrow. Any way to prop the blend door open if the motor is stuck to temp it?
Old Dec 4, 2004 | 01:18 PM
WildWilly's Avatar
Ok, heater core is good, blend door is in tact. Not sure if motor is ok. I think the temp switch on the dash might be bad. If only ford parts was open on Sat. Guess I'll have to wait until Monday to see if that's what it is.
