Panel air intermittent
Old Nov 23, 2004 | 09:12 PM
chimael's Avatar
Hi Guys -
Here's a weird one...
When I have the blower on (air or heat) and it's going through the panel, if I hit the accelerator the air STOPS coming out the panel and comes out somewhere else.
I have replaced the blend door actuator, the vacuum control motor for the defrost/panel (since I have not had any defrost controls at all), and the floor/panel vacuum control motor works fine.
This problem existed before I changed any of the above parts, but the air did not come out any of the 3 main exits (floor,panel, def) that I could determine.
Thanks,
Mike
Old Nov 24, 2004 | 08:20 AM
projectSHO89's Avatar
You have a small vacuum leak on the line that runs from the engine compartment to the control head or in the control head itself.
Steve
