Chevy problems
Old Jul 26, 2004 | 06:19 PM
ChevySniper's Avatar
Chevy problems
I would expect this from a Chevy but not my Ford.
I recently replaced the oe serpentine with a Gatorback and when I started my truck back up it was whining like Kobe after a Lakers loss...
It was very high pitched and it only does it when the a/c is turned off. If I turn it on, it goes away. My truck is only 9 months old, could it be possible that the a/c is going out?
Old Jul 26, 2004 | 08:07 PM
Richard D's Avatar
Sounds like the compressor to me. Since your truck is under warranty seeing how it is only 3 months old I would take it into Ford and have them take care of it.
Richard
Old Jul 28, 2004 | 02:42 AM
Pestco1's Avatar
Did it make the noise before the belt change. If not, any poss. that it is not installed quite right. I know that sounds bad but it is actually easy to route it so that it works ok but is not going around the pulley s right........ Just food for thought
Old Jul 29, 2004 | 09:49 PM
yeah, I noticed a slightly strang noise before I changed the belt. Also, I routed the belt like the diagram under the hood.
Old Jul 31, 2004 | 02:04 AM
Pestco1's Avatar
Might be worth your time to remove the belt agian and turn all of the pulleys by hand one at a time. You might find one that is not right and be able to lube/ replace it. Idlers can make noises that come and go depanding on the load put on the belt.
