Dripping lines on passenger floor...
I have been having a very small amount of water dripping from the lines under the dash on the passenger side of the truck, and this has occured regardless of whether the AC has ben on or off during operation of the vehicle. Any ideas, or should I be concerned?
That was where the heater core was on all my previous vehicles, a drip into the interior from under the pass. side dash was a blown heater core. I do not however know where they are located on a ford truck. sorry ..... if i'm of no help...
' 04 f-150 xlt 4x4
reg. cab flareside
drk toreador red
https://www.f150online.com/galleries....cfm?gnum=4362
' 04 f-150 xlt 4x4
reg. cab flareside
drk toreador red
hey I have the same problem with my 03 ford. leaking water into the floorboard. took it to the dealer and they said the drain tube was plugged from mudding. solved part of the problem. still leaks under the carpet. they cant find where it leaks from so i pulled the plug out of the door channel on the passenger side. no more water under the carpet>>>
