A/c Help
Old Jun 22, 2004 | 04:20 PM
bornagain's Avatar
A/c Help
MY A/C IS COMPLETELY OUT OF COOLANT(01 F-150), HOW CAN I GET THE COMPRESSOR TO KICK ON TO TAKE A CHARGE?
Old Jun 22, 2004 | 08:58 PM
TexfordD's Avatar
Pass side just below the battery there you'll see a switch attached to the high side line of the A/C...pull the connector and short across the the connector with a paper clip...compresser will come on and start charging fast...do not hold the can upside down...if you want a quick charge put the can in a can of hot water as soon as you start charging but make sure you remove it as you get close to slow the charge so you won't over charge...run the a/c on max fan on high..rpm around 1500.....and put a high volume fan in front of the condensor coil to force air through it....take your time and place a temp gauge in one of the center dash vents so you can see the drop in temp...it would seem that you have a leak...it could be in 3 places....there at that cut off switch...at the condensing coil (Lotcus can pierce a tube but most likely a rock)...or the seal on the compressor shaft behind the clutch
Old Jun 23, 2004 | 04:20 PM
bornagain's Avatar
TRIED TO SHORT ACROSS SWITCH BUT COMPRESSOR WOULD NOT KICK ON, ANY MORE SUGGESTIONS?
Old Jun 23, 2004 | 04:27 PM
guzman_marcos's Avatar
short the plug it should engage
check for blown fuse!
Old Jun 23, 2004 | 09:14 PM
TexfordD's Avatar
Not the switch ...the connector...yep check for a blown fuse...check the connection at the compressor clutch itself...is it loose or full of dirt?
