A/C still blowing hot and I did everything
Old Jun 23, 2004 | 04:23 PM
dbag's Avatar
OK. I read all the threads (I think), performed all the checks and tests and I still cant figure it out. My AC blows hot air always. No leaks and has a full charge. Blend door is not working. No power to the compressor from the dashboard control unit. All fuses are good. The control **** is good too. I was going to take to an auto electrical shop and let them figure it out, but if someone here and tell me what it is, that would be alot cheaper...haha. Any suggestions? Its a hot **** in south eastern NC! Help.
Dan
97 F150 XLT Long bed
Old Jun 23, 2004 | 04:30 PM
guzman_marcos's Avatar
Does compressor engages?
Try bypassing the switch if not
Old Jun 24, 2004 | 02:08 PM
dbag's Avatar
compressor does not engage. How should I bypass the switch?
Old Jun 24, 2004 | 03:25 PM
Place a jumper
take a piece of wire, umplug the connector near your service port from the switch and jump it. Turn on engine and AC and check if it works
Old Jun 24, 2004 | 04:00 PM
Wilson502's Avatar
sounds like a low pressure switch is bad.
