I survived the heater core replacement
Whats cheaper and easier?
A. Buy the correct solder tools and learn how to "reflow a solder joint" on the back of the cluster; or
B. Buy a used low mileage newer model cluster from a salvage and replace my original; or
C. Other. If so, please explain.
Definately easier and cheaper to fix it. Radio Shack has soldering irons for about $25. Or take it to someone that has a soldering iron and knows how to solder. Even if you give them $20, you are still getting it done cheaper.
There is no easy way in. I'm half way through the procedure. Under the dash are the vent tubes that run the width of the cab. I never knew there could be so many plastic pieces in the dash! The bed of my pickup is filled with plastic and I still had to put the main dash piece on the floor of the garage. Cutting is not really an option as you might cut any number of wiring harnesses.
I have replaced the blend door and heater core and am finally ready to reassemble the dash. Here's a few pictures I took along the way.
https://www.f150online.com/galleries...w.cfm?num=7272
