A/C Drain Line
Old Jul 1, 2003 | 01:12 PM
jmsmbry's Avatar
A/C Drain Line
Does anyone know where the A/C drain line is on a F150? I noticed some condensation leaking inside the truck below the glove box a couple of days ago.
I assume the drain line must be clogged. Any help would be appreciated. thanks
Old Jul 1, 2003 | 09:11 PM
03f150man's Avatar
what year is your truck.
Old Jul 2, 2003 | 07:29 AM
jmsmbry's Avatar
I'm sorry, it is a 1998 f-150 supercab.
Old Jul 2, 2003 | 08:26 PM
Tailgator's Avatar
It's on the lower right side of the firewall, a small 1/2" tube protruding out. It may or may not have a hose/nipple on it. There was a TSB on your year for oxygen sensor failure due to moisture dripping on the sensor from the A/C drain. The TSB fix was to reroute the drain away from the sensor. If yours had this done, you might check & see if this is plugged.
