AC smell
Old May 30, 2003 | 11:17 AM
waterrat's Avatar
AC smell
I have a 01 expy and when i turn my truck on after i get out of work my ac smells pretty bad and then it goes away... i have had it in the shop and they deoderized (sp) it and that was about a year ago.. is there anything i can do?
Old Jun 3, 2003 | 11:47 AM
J-150's Avatar
it could be condensation in the vents that has gone mouldy
try an aftermarket deodourizer that you spray into the air intake (at base of windsheild) while running the AC at full fan.
This usually takes care of it.
Old Jun 6, 2003 | 08:40 AM
97 XLT 4X4,4.2L's Avatar
It is probably the condensation is getting moldy. Simple solution: when you're using the AC, switch it off about 10 minutes before you arrive at your destination and turn just the fan on high. This will help dry the condensation up and get rid of the odor when you turn it back on. I'd be surprised if your problem is anything more than this.
Good luck.
Old Jul 3, 2003 | 03:36 AM
Dennis's Avatar
Never leave your A/C set to MAX or OFF when the truck is shut down for a period of time during the cooling season. In MAX or OFF, the outside vent is shut and this condition is good for the growth of mold in the system. With the outside vent open, outside air can continue to circulate through the system and this will help prevent the growth of mold.
Get the A/C deodorized with an antibacterial spray and from then on, keep that outside vent open when you shut down the engine.
