A/C question
Old May 8, 2003 | 10:33 AM
SaltWaterFish's Avatar
Question A/C question
I just bought my 99 150 back in Feb. I tried the A/C back in April and it didn't work.
This is what I've found so far.
With the A/C turned on, the compressor will cycle on for 2 seconds then off for 7seconds and continues to do this.
When I bypass the cycling pressure switch the compressor will run. I did not let the compressor run this way b/c I thought it may damage it if there was no freon in the system.
So, my question is. Can I be low on freon or is the switch bad? Is it something I can fix myself without getting raped by a dealer?
Old May 8, 2003 | 10:55 AM
Dvds's Avatar
Probably low on freon(F134). You need to have an AC shop check it with gauges. Low on gas will cause short compressor cycles.
Old May 8, 2003 | 10:14 PM
FordMasterTech's Avatar
Total cycle time 10 seconds?
Low on freon, no doubt..
Here's a tip and take it anyhow you want but repair the problem, don't try the leak sealer in a can. Those things usually cause more harm than good.. I have seen leak sealer cost customers in upwards to $1600 for AC repairs because it can clog up everything from the orifice tube to the evaporator itself. Can also harm the compressor ..
FordMasterTech
Old May 9, 2003 | 10:05 AM
Cool
Thanks for the responses. I hope a recharge is all I need!
Old May 9, 2003 | 12:21 PM
Dvds's Avatar
As FordMasterTech said, the only way you could be low on freon, is for it to leak somewhere. May be as simple as a loose connection, but you do need to locate, or have a shop locate the leak and fix it. Hope it all works out for you. My 99 had a leak, the dealer added dye to the freon, and was able to locate the source using a black light.
