A/C Controls
Old Apr 15, 2003 | 04:07 PM
pinetree's Avatar
Thumbs down A/C Controls
Have 1999 F150 extended cab, Many problems. Most I corrected. At present , when i turn on a/c only HEAT comes out, No problems previous years. Out side temp. App. 70 deg. Can use some help. Thanks, Pinetree
Old Apr 15, 2003 | 07:35 PM
TexfordD's Avatar
spounds like the blend door won't open
Old Apr 17, 2003 | 08:23 PM
pinetree's Avatar
How can I check this out, location of blending door.
Old Apr 19, 2003 | 06:41 PM
FordMasterTech's Avatar
Pull the plastic push pins that cover the bottom of the dash,..
near center hull.. There is a connector with several wires..
I think the connector is white.. anyhow that goes to the blend door motor. To see if your blend door motor is working correctly,
place,,hmm WEDGE your finger until you fell what is like the female end of a 1/4" extension (on the motor).. Switch the hot/cold **** from one direction to the other.. it should take less than 5 seconds to make the sweep... If it takes longer than that,
The blend door is broken.,.If that's the case then you are gonna have to pull the dash to fix ..
Keep me posted as to your findings..
Good Luck!!!
FordMasterTech
