No heat from heater
Old Dec 19, 2002 | 01:42 PM
fordjim's Avatar
No heat from heater
I can only get cold air from the defrost/heat settings -no heat at all
Old Dec 31, 2002 | 01:47 PM
Rockpick's Avatar
Moderator &
This could be any number of things... I would recommend a dreaded trip to the Stealership... I'll keep you in my prayers.
RP
Old Jan 8, 2003 | 12:20 PM
36fan's Avatar
sounds like either a heater core problem, or the cable thingy has come off of the temperature dial - hopefully the cable came off
when you turn the temp dial, does it feel like it has any resistance on it?
Old Feb 5, 2003 | 11:18 AM
lopez's Avatar
Check your water level. I had the same problem, no heat. I noticed I needed water in the radiator. I added about 1/2 gallon and now the heater works fine.
Old Feb 6, 2003 | 09:27 PM
97Expyguy's Avatar
I had a problem where I got no heat @ my feet. Took to the stealership and it was a $10 motor than controls the vents on the floor.
Too bad it took 3 hrs of labor to fix the $10 part!
Good luck!
Old Feb 7, 2003 | 08:59 AM
sporty's Avatar
My wife's car was not getting warm at all. You could drive it for 50 miles and it was just barley starting to warm. Turns out that the Thermostat was butsted into about three different pieces. $8.00 later, and 20 min of work and the car was warm again.
Old Feb 7, 2003 | 12:18 PM
titank's Avatar
I agree, start with the thermostat. You can do this yourself and you probably needed fresh coolant anyways!
Old Feb 24, 2003 | 09:31 PM
99 Bauer's Avatar
Hey, I'm having the exact opposite problem. If you live anywhere near me, maybe we could trade Expy's from time to time. Mine blows ONLY heat in the front. I'm willing to trade!
