iPad as a head unit
As far as doing an install like SoundMan I don't see any reason why the age of the vehicle would matter. Now for using an iPad to control the heat/ac system if your system has wires at the ***** I don't see why with a little work it wouldn't be possible. Now, if your truck operates some of the controls via vacuum in place of electronic controls some slight conversion would be required first making it a bit more work... not that this wouldn't already be a bit of work lol....
Mines in the works as well. should have it done in a month or so. The work is actually easy, i dont think many people would attempt to follow a 'how to' because of all the plastic or fiberglass work involved.. but either way, i already started modifying the dash piece and i've been documenting it.
It wouldnt work the same in a 99 because the thing that makes the system work in the video is the USB input, and the steering wheel controls with Sync. The only way for Soundman to change the source of the sound in his truck, he needs to hit the sync voice button and tell sync to turn on sirius, or am/fm.. In a 99, you would have to run a headunit with a built in usb port and then plug the ipad into it. So the ipad could be in the center of your dash, but u sill still need the headunit to change your source from CD, Radio, or ipad. Hopefully this makes some sense
I disagree, THIS is the perfect size. This is my top slider concept, push to open and push to close, all hinged. Ipad removes in seconds. The only top slider that looks permanent that anyone's ever seen!
Got any pointers on making that or any step by step pictures?
Freakin' SHARP, but more info please!
Since u guys seemed interested i started a thread and posted the pictures that i had.. check it out and let me know what u think!
https://www.f150online.com/forums/20...ml#post4914776
