Installed headunit, no lights.
Old Oct 15, 2010 | 05:09 PM
russo2's Avatar
I recently installed a sony head unit in my truck, now I have no dash lights. All the other lights work and the hu has illumination.
Is there a wire from the old wiring harness that needs to be connected to a power?
And yes I did check the fuses.
Old Oct 15, 2010 | 08:17 PM
XtremeBawls's Avatar
Sure you didn't blow a fuse? I don't know how many times I've heard people say they checked the fuses, only to find out they actually had blown one after checking a million other things, and then checking the fuses again.
Old Oct 15, 2010 | 10:13 PM
Sundevil2188's Avatar
disconnect any of the orange wires behind your new sony and see if that fixes your problem.
Old Oct 15, 2010 | 11:23 PM
russo2's Avatar
I'm sure I didn't blow a fuse, I checked them all and even replaced the one for dash lights just to make sure.
I'll disconnect the orange wires and see if that works. I didn't install it my friend did so I'm not really sure.
Thanks.
Old Oct 15, 2010 | 11:28 PM
Well in that case, sundevil is probably right about the Illumination wire.
Old Oct 17, 2010 | 07:55 PM
russo2's Avatar
I disconnected the orange it did nothing..
This is an older sony if that helps any.
Is there something from the old wiring harness that should be connected somewhere?
Old Oct 17, 2010 | 08:51 PM
russo2's Avatar
Now no matter what way I hook it up if I have dash lights they stay on constantly regardless of the headlight swtich or everything comes on as if the ignition if on accessory when the key isn't even in the ignition.
I'm so lost.
