dnx 8120
Old Jul 16, 2010 | 02:37 PM
lawnmowerman160's Avatar
dnx 8120
hello all, im new to this so maybe i can get it right, anyway i bought the kenwood 8120 and have been trying to change the start screen but have had no luck, i download the convert.dat but it will not open, i open it with notepad but its a bunch of letters and numbers, i tried rapidshare but want let me download anything, i plugged the usb in and reset the unit and chose the emblem i wanted from the usb and hit enter says loading and i see the emblem for a second then it takes me back to the oem screen and i turn unit off and back on and its the kenwood screen again, what or how do i get this convert.dat filea? im not very good at files and how they work so please if u can help me change this startup screen..thank you, james
Old Jul 19, 2010 | 12:01 AM
Fabian06SC's Avatar
As far as i know you cant easily change the loading screen on the kenwoods just the background.
Can you post where you found the info on how to change the load screen?
Old Jul 19, 2010 | 05:21 PM
dnx8120
hello, i found the download to change the startup screen and it worked successfully, download is from rapid share..anyway thanks
Old Jul 19, 2010 | 07:26 PM
Fabian06SC's Avatar
I Stand corrected seems like info has been around since late 08 on how to do this.
After a bit of research i found out how to change it since our new member couldnt give me a reply. You will need a convert program file that you can download here
http://rs178.rapidshare.com/files/121330272/convert
(i havent tried the file yet so DL at your own risk)
To enter setup Mode, Press and hold FNC & EJECT keys, then press RESET Key.
· Release reset key, and hold FNC & EJECT Key until illumination
activates.
· Connect the USB Thumb drive containing image file and convert program.
All files must be in the root directory.
· There is no extension on the convert program.
· If you want to change the opening image to your own image (i.e., company
logo), Press OEM Image.
· The OEM Image will be grayed out till files are seen on USB
device.
· If you want to put original KENWOOD opening back, press KENWOOD image.
· Select the image you want to use.
· When the image is loaded, select Enter. Your new opening will remain for
few seconds and then switch to the Source Select menu.
Phone: 1-800-536-9663 x 1918
Fax: 1-559-324-4594
Email:http://Kenwoodusa.com/Contact"
Also a few notes;
Kenwood unit stretches the load screen a bit so...
It looks like the proper size to make your startup screen is 480x262, then resize the height to make it 480x234. This way, the proportions remain correct.
and lastly
remember that this is a unix/linux based operating system for the Kenwood double din line, and these systems do not tolerate spaces between file names. so...., if your image filename is GMC LOGO.jpg, it will not work. You must change it to gmclogo.jpg or gmc_logo.jpg or something along that framework....
All quotes lifted from AVSforum. Thanks for the info guys
