speakers stopped
Old Mar 31, 2010 | 09:22 PM
jasonhill's Avatar
speakers stopped
I went to swap out from one aftermarket stereo to another in my truck (98 F150) and now the speakers will not work. I hooked everything back up the same way as I have done this in the truck before. Now no noise. I checked at the radio and it works there but it doesn't go to the speakers. Any help would be great!! Thanks Jason
Old Mar 31, 2010 | 11:37 PM
Brad Johnson's Avatar
Originally Posted by jasonhill
speakers stopped
Make them start?
Are you running an amp or powering the speakers directly from the deck?
Brad
Old Apr 1, 2010 | 02:10 PM
jasonhill's Avatar
off the deck
Old Apr 1, 2010 | 02:17 PM
Using a wiring harness adapter or did you do the cut-and-crimp connection thing?
Brad
Old Apr 1, 2010 | 02:39 PM
jasonhill's Avatar
it has the harness on it.
See, when i bought the truck, it had a Kenwood CD player. i got an indash and installed it never any problems. Now I took the indash out went to put the kenwood in and now the problem.
Old Apr 1, 2010 | 03:44 PM
With the harness, did you cut the Kenwood wires off and reconnect it to the wiring from the new HU? If so, did you make absolutely, positively sure that you have everything right, including the ground?
Brad
