Bluetooth microphone routing....
Old Nov 21, 2009 | 06:50 PM
Neurotoxin's Avatar
Hi all. I just bought an Alpine CDE-103BT and I'm at a loss on where to route the bluetooth microphone wire/microphone. I want the location as easy as possible to install....
Thanks in advance!
Old Nov 21, 2009 | 10:51 PM
gixxer's Avatar
here's where i put my mic from my avic z110bt
DSCN1155.jpg?t=1258861817
Old Nov 21, 2009 | 11:17 PM
rednoved's Avatar
My mic is at the top edge of my driver side A-Piller. I can get a picture of it tomorrow. It's not too hard to route.
FWIW, I'm using a Parrot Bluetooth Kit.
Old Nov 22, 2009 | 03:35 AM
Sundevil2188's Avatar
We mount 9/10 of the BT mic's at the top of the A pillar or dead center above the rear view mirror.
Old Nov 22, 2009 | 08:35 AM
Neurotoxin's Avatar
Where did you run the wire? Along the top outside edge of the dash? Did you have to remove the A-pillar cover?
Thanks!
Old Nov 22, 2009 | 08:38 AM
Neurotoxin's Avatar
Pretty good idea.......any issues with it there?
Old Nov 22, 2009 | 09:51 AM
gixxer's Avatar
none what so ever. i use it often and haven't had any issues.
Old Nov 30, 2009 | 04:58 PM
Titan357's Avatar
I install them for a living, working for a cell phone provider.
Above the rear view mirror, the headliner will come down, may have to start it closer to the doors though, it can be stiff.
If your truck is 05+ it will be a breeze to hide all the wire, run it from the mirror to the pillar, then if you pull the pillar a bit you can put the wire on top of the head liner and run it down the pillar.
Take the little panel off ( where the dash ends ) and run the wire through there, the glove box can drop all the way down, it has a little rubber piece that stops it, just push the glove box in a little and it will come right out.
There is a massive space behind where the raido goes in a 05+, so you can hide all the wiring and boxes there.
should be easy, if its older than a 05, its still easy, just slightly different, the pillar covers in the older models comes all the way off, the 05+ does not come off so easy.
if its a 2000-2004 the panel below the steering wheel is a great place to hide things.
