Ordered my Alpine 9883
Old Dec 14, 2007 | 06:14 PM
shaunakadub's Avatar
Hey guys,
Finally ordered my Alpine 9883. ($169 with installation hardware and IPod cable, plus free shipping.)
Was wondering if anyone could give me a little heads up on what to expect. I've seen around the forums that it is a fairly easy install. I also know you need some sort of key to take the stock unit out... is there a universal kit I can purchase or do I need something Ford specific?
Any other hints/ideas ect. are welcome!
Thanks!
Old Dec 15, 2007 | 05:24 AM
Low_e_Red's Avatar
Originally Posted by shaunakadub
Hey guys,
Thanks!
Your key is a 7mm socket. You have a new body not the old. Radios are different...
You should get everything in the installation hardware if from Crutchfield...
Old Dec 15, 2007 | 11:59 AM
Yea I did order from Crutchfield after seeing a lot of posts here about them.
Another quick question:
For those of you with the single din unit that now has a cubby space below the radio, how did you route the IPod cable (Alpines connect in the back)?
I was thinking of drilling a hole through the cubby space so I'll have a place to put the IPod when I'm not controlling it, and easy access to the wire.
Old Dec 15, 2007 | 02:07 PM
Hawaii-50's Avatar
I just installed my 9885 yesterday and it sounds great. I also got mine from Crutchfield-it was on sale for $249 (originally $299) and it came with the free IPod cable, installation kit, and wiring harness. Install for the head unit alone took maybe an hour after soldering the connections. Low e red is right about the 7mm socket. Very easy install. Be really careful prying the radio trim off. Start at the bottom and work your way to the top. I just snaked the IPod cable to the back of the glove box and keep the IPod there-I didn't want to drill anything. I also wired up 2 10" Alpine subs in a Supercrewsound box powered by a Punch 75 (the amp fit perfectly in the dash behind and slightly below the head unit-I couldn't figure out where else to put it) and it sounds incredible. I had already replaced the factory speakers with Alpine units-all I need now is a 4 channel amp. You'll be surprised how easy it is to do.
Old Dec 19, 2007 | 01:03 PM
Installed it last night and it went very smoothly!
A few questions:
Anyone know how to use the manual dimmer option? I have it set to manual, but don't know how to adjust it.
Also, HD Radio Ready... what do I need to get the HD stations?
Old Dec 19, 2007 | 04:01 PM
rjp's Avatar
rjp
http://www.crutchfield.com/S-8ilZIHq...p?i=500TUAT500
Old Dec 24, 2007 | 12:15 PM
Devildog101's Avatar
A few questions:
You use the panel dim for the truck...
If you increase the dim, the radio will dim with it if you hooked it up correctly.
Old Dec 24, 2007 | 12:54 PM
I wired it exactly as it needed to be. Orange to Orange (Illumination/Dimmer).
I've read around and it seems like a few people are running into this same problem.
I've noticed when I have it on manual and I use the dimmer switch on the truck, the radio flickers when I lower the lights to a certain level, but regains its normal brightness once returned to the higher dimming setting.
Weird stuff, but it doesn't bother me much at all... so no biggie.
