Alpine IVA-W200-- I need your help!
Old Oct 13, 2007 | 05:12 PM
Zaairman's Avatar
Ok guys, here's the deal. My new to me IVA-W200 doesn't have any sound output. This just started yesterday, and only seems to happen when the temperature is below 60*. It will beep and all of that fun stuff, but no sound from the speakers, no matter what mode it is in (Sirius, Radio, DVD, etc). It is NOT a wiring issue. All wiring has been triple checked. Factory headunit works when put in place of this unit. Any suggestions on what to do? I'm in a bit of a pickle here... The unit was purchased online less than a year ago, but apparently the only "authorized" online dealer from Alpine is Crutchfield. Anybody wanna work up a deal and share a receipt?
Old Oct 13, 2007 | 08:01 PM
mark03screw's Avatar
Sounds like you bought a busted HU. I have the same one and it works fine. Granted my back drivers side speaker doesnt work, but i'd blame the wiring for that one. I just haven't had time to fix it; aka too lazy to take my deck out, it looks so pretty. Maybe you bought a crappy wiring harness(i cant remember what they're called off the top of my head) to plug your deck into. Try plugging in the wiring harness and use a volt metre to see if you're getting any power through the harness.
Old Oct 13, 2007 | 11:30 PM
Zaairman's Avatar
My wiring is good... the unit turns on and functions exactly as it should. There's just no sound output on any of the speakers.
Old Oct 13, 2007 | 11:45 PM
Low_e_Red's Avatar
Whats odd is some of the Alpine's beeps come through the spks. Do you have the amp defeat on? Is the mute wire touching 12v+/Gnd? Can you post pics of wiring/menus?
I might be able to help with the reciept. Need to talk to you abt it and all.
Old Oct 13, 2007 | 11:47 PM
Zaairman's Avatar
Alpine's beep comes through the unit. The mute wire is capped off. No settings have been changed from the last time it was working. There is a new ground pop sound that comes through the speakers when I turn the truck on, I've discovered.
Old Oct 14, 2007 | 03:40 PM
Zaairman's Avatar
Guess I should add, it's about 75 - 80 right now and the radio is working... No settings have been changed, nothing has been changed since last night when it didn't work...
Old Oct 14, 2007 | 07:09 PM
allstar8806's Avatar
i have the problem where my w205 will play audio from the radio and ipod but when i put a cd or dvd in it has no sound. i know it is reading the dvd and cd beause the movie will play but no audio. it was not always like this just one day stoped playing audio for dvd and cd
Old Oct 15, 2007 | 01:34 PM
Zaairman's Avatar
On the phone with Alpine now...
They said to send the unit in for service. Anybody purchase their W200 from an "authorized" dealer less than a year ago?
Old Oct 19, 2007 | 07:32 PM
GJ Screw's Avatar
Sounds like your amp out wire (remote turn on ) is dead- did you check it with a multi meter?
Old Oct 20, 2007 | 02:47 AM
DRJ's Avatar
DRJ
I bet it's a coincidence...have you checked your speakers? use a meter to check that you're not getting a grounded speaker. check it at the HU when it's not working, and check your speaker wires or terminals to make sure they aren't rubbing on anything..oh I guess I should add that if one speaker is grounded then all the sound gets cut out. If you find a grounded speaker wire, check if it's coming FROM the HU. it's possible that the HU is the source of that noise/grounded wire when you turn it on..s**t happens
Old Oct 20, 2007 | 06:05 AM
Low_e_Red's Avatar
I have a service plan through BBY.
Old Oct 20, 2007 | 11:47 AM
Zaairman's Avatar
It's not the speakers. The speakers are working fine right now with the stocker headunit in.
Old Oct 26, 2007 | 05:15 PM
Zaairman's Avatar
Little update... Alpine replaced most of the electronics on the inside of the unit, and it'll be here Tuesday.
Old Nov 4, 2007 | 08:17 PM
sean_somer's Avatar
zaairman do you have any pics with the new hu in?
Old Nov 4, 2007 | 10:30 PM
Zaairman's Avatar
