Alpine IVA-W200-- I need your help!
Old Nov 5, 2007 | 04:00 PM
allstar8806's Avatar
Originally Posted by GJ Screw
Sounds like your amp out wire (remote turn on ) is dead- did you check it with a multi meter?
if it is what does that mean. when i connected the bypass to it i cut the end off that had the little connector on it when just used butt connectors to crimp the bypass wire to that amp out wire could that have anyhitng to do wiht it
Old Nov 6, 2007 | 11:29 AM
Low_e_Red's Avatar
Uhh no. Thats just a terminal for ease...
Old Nov 6, 2007 | 12:27 PM
ok how do i fix it if it is dead
Old Nov 11, 2007 | 06:35 PM
bump
Old Nov 12, 2007 | 06:25 PM
bluesupercrew05's Avatar
shoulda bought the kenwood
Old Nov 14, 2007 | 11:07 PM
Low_e_Red's Avatar
Alpine is the only way to fix that... Sorry. If you need an amp turn on. Wire remote to your main ign wire... Or you can run a relay off of the one behind the radio.
