Head Unit 97' F-150 Question
Old 08-01-2007, 12:02 AM
bg98f150's Avatar
I have a 97' F-150 XLT with a AM/FM Cassette with CD control for the 6 disc remote CD changer. Does the factory head unit have RCA jacks to hook up an amp? Just wanted to check before I pull it out.
Old 08-01-2007, 09:14 AM
APT's Avatar
APT
APT is offline
I've never seen an OEM head unit with RCA pre-amp outputs. That's any OEM, not just Ford or the F-150. You could use a line output converter or buy any new $80 HU.
Old 08-01-2007, 06:28 PM
worland's Avatar
Nope. It definitely does not have RCA outputs.
To hook the factory stereo up to an amp you either need a line level converter or an amp with speaker level inputs (aka high level inputs). I prefer going with the amp with speaker level inputs over the line converter. Much more simple and reliable.
Old 08-29-2007, 02:58 PM
phillbus914's Avatar
Anyone know what wires in the radio harness go to the rear speakers (to splice into an RC converter) I have the same setup... 97 F150 with factory 6 disk changer and I'm trying to add an amp to my factory head unit.
I have 2 harness that go to the head unit... they are..
1st plug has 16 wires... they are
1. Grey
2. Purple
3. Orange / Black
4. Green / Red
5. Green / Black
6. Black
7. White / red
8. Green
9. Brown
10. White / orange
11. purple / white
12. Lt. Blue / Black
13. Lt. Blue
14. Yellow
15. Lt. Brown
16. Lt. Blue / pink
The other plug (I think goes to the disk changer) has 6 wires...
1. Green / Purple
2. Black
3. Black / Purple
4. Lt. Blue / Black
5. Black / Green
6. Dark Blue
Anyone know which of these wires are for the rear speakers?
Thanks.
thanks.
Old 08-29-2007, 04:43 PM
DRJ's Avatar
DRJ
DRJ is offline
Sounds like it's the Metra harness 805511, if so the wires should be...
+12V DC Battery(Constant) Lt.green/purple
Switched Accessory Black/pink
Ground Black Also black/light green
Remote Turn On(output) Lt.green/black To CD changer pin 8
Illumination Lt.blue/black
Mute Dark blue
Left Front + Light green Line level output
Left Front - White/orange Line level output
Right Front + White/red Line level output
Right Front - Brown Line level output
Left Rear + Lt.blue/black Line level output
Left Rear - Yellow Line level output
Right Rear + Purple/white Line level output
Right Rear - Light blue Line level output
The speakers should be the 6 pin plug (the plug should be a square black/metal...if not)
metra 801771 =
+12V DC Battery(Constant) Lt.green/violet
Ground Black & black/light green
Remote Turn On(output) Lt.green/black To CD changer pin 8, and to rear integrated control panel pin 10, if equipped.
Illumination Lt.blue/red
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Gray/lt.blue To the rear integrated control panel, pin 7.
Left Rear - Tan/yellow To the speaker and to the rear integrated control panel, pin 8 (if equipped).
Right Rear + Orange/red To the rear integrated control panel, pin 5.
Right Rear - Brown/pink To the speaker and to the rear integrated control panel, pin 6 (if equipped).
Old 08-30-2007, 12:52 PM
I found that my truck has a factory amp... That would explain the awesome sound from my factory radio in this truck. Only thing it lacks is some real bass, that's why I wanted to keep the factory radio and wire in a sub.
Anyway the amp is barried in the dash under the radio. I found a plug from the amp that has the wires I was looking for.
RR + black/purple
RR - orange/maroon
LR + brown/yellow
LR - gray/lt. blue
So I could tap into these wires (after the amp) or I could tap into the line level outs on the radio plug.
Which do you guys think is better?
Quick Reply: Head Unit 97' F-150 Question
