Pie wiring for power in Factory Radio HU
Old May 31, 2007 | 11:23 AM
GeronC's Avatar
Can someone please tell me the wiring colors to pull power off of the HU to hook up a PIE? I have an 05 150 XLT. I would like for the PIE to come on and off with the radio or else i would just tap into the cigarette lighter power. If i happen to look over the tread, will you send me that link then please? Thanks.
Old Jun 1, 2007 | 09:09 AM
lenore's Avatar
pin 1 on the 24 pin jack on the head unit is 12v power, and pin 13 is ground, however you could use any chassis ground point on the dash.... You could tap off the wire on pin 1 and get your 12volts... Sorry I dont have the wire color, pin 1 is on the very end of the connector....If you have a voltmeter you will find it.
Old Jun 1, 2007 | 09:29 AM
GeronC's Avatar
Thanks for the info. Do you know who has the diagram of the connector? I tried finding it again and can't. Thanks.
Old Jun 1, 2007 | 10:57 AM
lenore's Avatar
discountcarstereo.com then search
