06 150 headunit to 06 Expy Help!
Old Mar 9, 2007 | 08:14 AM
smkeater's Avatar
Exclamation 06 150 headunit to 06 Expy Help!
Ok, Here goes, I removed the Hu from my truck and installed it in the wifes 06 Expy. The problem im having is the radio buttons wont light up when the headlights are turned on, PIA at night. Anyone run across the same problem? I tried 2 different HU's and the same problem exisits, swapped the original single disk and lights work fine. Im guessing different wire config. I would appreciate any thoughts or help.
Old Mar 9, 2007 | 09:45 AM
natedog04scab's Avatar
yea sounds like a wire issue. there will be a dimmer+ and a dimmer- wire they must not be on the the same locations of the wire harness. everything else wqorks? wonder where the dimmer wires are hooked up now
Old Mar 9, 2007 | 12:34 PM
smkeater's Avatar
Everything on the radio works fine. Its just a PIA at night when theres lighted buttons. I dont drive the expy that much so Ill live with it..
Old Mar 9, 2007 | 12:36 PM
smkeater's Avatar
Everything on the radio works fine. Its just a PIA at night when theres lighted buttons. I looked at the pins in the harness they are exact as the 150, only thing im wondering is they use the Chrysler ant adater, i wonder if that acts like a ground for the lights! I dont drive the expy that much so Ill live with it..
