Aux. input with Sirius
Old Jul 9, 2006 | 12:00 PM
Cdn-Redneck's Avatar
Can I hookup my Sirius sportster to my aux input with RCA cables on my Stock HU. I have an 05 Scab XLT with the single disk cd. I currently just use the FM signal wire but would like to hard wire it in if possible. I would like to add an amp as well if there is an easy way to do this.
Old Jul 9, 2006 | 12:21 PM
Tbird69's Avatar
As far as I know you need to buy a P.I.E adaptor that lets you plug into the AUX jack on the rear of the HU.
Old Jul 9, 2006 | 01:27 PM
Can I buy one from a car audio shop?
Old Jul 9, 2006 | 02:23 PM
Tbird69's Avatar
Should be able to but they're not cheap, in the $70-$90 range.
Old Jul 18, 2006 | 12:26 AM
05ford22's Avatar
So if you have a P.I.E adaptor hooked up the the aux button, then when you press the aux button it will switch over to the sirius receiver, and you can still control it from the seperate receiver? Does that sound right?
Old Jul 18, 2006 | 10:46 AM
jmpancoast's Avatar
I have my Siruis hooked up to my head unit with PIE. The volume is controlled from the truck's head unit. All functions of the satellite radio are controlled from teh Sirius head unitor the Sirius remote. The sound is very good, much better than fm modulation.
Old Jul 19, 2006 | 02:59 PM
05ford22's Avatar
Where can I find a PIE Adapter for a good price? Also, how did you connect the wires together, any instructions would be very very helpful. Thanks.
Old Jul 19, 2006 | 03:34 PM
jmpancoast's Avatar
This is a link for one source. They may not be the cheapest, but they do offer a good price. This unit is specific to the new body Fords. Everything plugs right in. Verify the application is correct before you order.
http://www.logjamelectronics.com/piefrd04aux.html
Old Jul 24, 2006 | 06:46 PM
mxrider38's Avatar
This may be a little off topic but what else would the aux. input be used for. Is there a way for me to hook my ipod to it?
Old Jul 24, 2006 | 08:10 PM
Apparently it is for a rear seat ent. unit. I think you would need the same addapter to add i pod.
