alpine 9833 power wire question
Old Mar 21, 2006 | 10:16 AM
stetsonguy's Avatar
Hi folks...
I just bought a 9833 off ebay. My question is since I will be using outboard amps to power everything, and subsequently will have the internal v-drive turned off, do I still need to route the power wire directly to the battery instead of just plugging it into the harness?
If I have it connected to the harness then when I power it on for the first time will it burn wires or blow fuses while I am going through the menus looking for the power ic to turn it off?
Old Mar 21, 2006 | 10:26 AM
RageOfOrder's Avatar
The deck should be fine to plug into the harness, especially if you're amping all the speakers seperately.
Old Mar 22, 2006 | 12:54 PM
stetsonguy's Avatar
thanks for the info...
And just out of curiosity where are some good easy to get to grounding spots up under the dash?
