first step to remove dash radio cover?
Old Feb 23, 2006 | 07:03 PM
50mustangs's Avatar
just bought a factory sub for my 06 F-150.. found wiring harness under rear seat. plugged sub in and nothing happened.. heard harness may not be plugged into head unit. I'm going to pull out head unit and check but don't want to break face plate. never really looked at it yet but I would like a little heads up if possible.... thanks
Old Feb 23, 2006 | 07:33 PM
coloradochip's Avatar
Hi, I just took mine off today, and I found that the easiest was was to start at the top and work your way down. I used one of those pain can opener toosl to pry it forward, and then pulled straight out. There is a great explanation on this site done bu ScottFcasni (https://www.f150online.com/forums/sh...readid=133164). It's awesome, but I found it much easier to start at the top rather than the bottom. The cover is very strong. It seems like it's going to break, but it doesn't.
Old Feb 24, 2006 | 01:00 AM
countyboy04's Avatar
I always start from the bottom and work my up the panel. No problems by doing it this way.
Old Feb 24, 2006 | 06:57 AM
jljue's Avatar
I've done it from both directions, but I also have used a putty knife with a shop towel or shop rag wrapped around it to keep from marring the dash.
Old Feb 24, 2006 | 11:11 AM
FX4_Guy's Avatar
As long as you pull straight out and give it a little elbow grease....you won't have any problems.
Old Feb 24, 2006 | 02:10 PM
nu-supercrew's Avatar
Hey, Can you post a pic of that harness? In particular,the shielded wires? I have to make that harness, and need to see the shielded wires, thanks!
