Problem?
Old Dec 3, 2002 | 03:28 PM
Harley01's Avatar
Problem?
I have a 2002, buld #7159. I have recently been noticing a problem with it. When my motor is cold and I go to start it, the truck moves slightly. This can't be good.
It doesn't happen all of the time. Has anyone else noticed this?
Old Dec 3, 2002 | 04:08 PM
ricekicker's Avatar
Registered User
The truck moves slightly?
Do you mean the truck moves/shakes like in a similar way when you rev the engine? --- If so...this is normal. Could it be that you are just paranoid? Give us a more detailed description so we can help you. Are you sure it only does it when it is cold? Maybe someone has answers for you right now...but I havn't heard of this problem....yet -
Old Dec 3, 2002 | 07:19 PM
chesterc's Avatar
Is it like a forward or rearward surge? If it is, then I would think that your column shifter (tranny) was not placed in "Parked" all the way and locked, which happens once in a while. If it's like what ricekicker said, it sounds normal to me.
Old Dec 3, 2002 | 07:23 PM
Fepony's Avatar
yeah
I noticed that too...it's like it is going to drive away without you but it doesn't. Reminds me of my old Sportster sitting at a light and you revved it...it would lurch? forward a bit.
Old Dec 3, 2002 | 09:05 PM
ricekicker's Avatar
Registered User
Also...do you park the truck on an incline? If so...try parking it on a flat plane and see if the problem still occurs.
ricekicker's Avatar
Registered User
Old Dec 4, 2002 | 12:23 AM
Dan_d_glassman's Avatar
Probably the parking 'pawl' is not entirely engaged or has a little slop in it. Ever notice how the trucks usually rock a little and you hear a 'pop' from the steering column after parking the truck?
...or you could be feeling the initial friction of the clutch packs slipping past one another.
I wouldn't be too worried unless it is really lurching forward.
Old Dec 4, 2002 | 06:02 AM
Harley01's Avatar
No, I thought I was paranoid at first, so I let it go. But it did it again last night. It was obvious. So, I made am appointement at the dealership to get it checked at . I'll let you know how it goes.
Old Dec 4, 2002 | 06:56 AM
outnumbered's Avatar
Harley01, mine has always done it, and I have 12,000 miles on her now.
Old Dec 4, 2002 | 07:33 AM
rhdf150's Avatar
The same thing happens in our Expedition. We have an automatic car starter
& when I look out the window the truck moves forward during start. I ignore it for now. I think it is all the torque/HP^^^^^^^^^^^^^
https://www.f150online.com/galleries....cfm?gnum=1142
Old Dec 4, 2002 | 10:38 AM
clonetek's Avatar
my lightning does it when it's cold.. as do a lot of other lightnings.
i don't park close to anything.
