Harley356
Old Aug 9, 2002 | 09:26 AM
PAUL BARASH's Avatar
Harley356
How do I post my truck picture and my mods everytime I post a thread?
Paul
Old Aug 9, 2002 | 10:08 AM
BillP's Avatar
Paul,
If you haven't already done so, go to your profile and update your signature. You can enter the mods and put an image to your picture you want to use (the pic has to be in your gallery). Get the URL to the pic from your gallery and put [IMG] [\IMG] tags around it in order for it do display.
When you post there are some options at the bottom. Check the box to include Signature and whatever you put in your profile signature will appear.
Old Aug 9, 2002 | 10:56 AM
Harley#356's Avatar
Paul, pretty much just what bill said, but i'll try and be more specific cuz i know it can be confusing the 1st time trying to do it. So here i go:
  • click "user cp" at the top of this page
  • Click "edit profile" from the bar at the top of the other page (not the 1st menu bar, the 2n'd one)
  • Scroll down and you will see "registration" then "optional Info" and under that a few lines down is "signature"
  • Type whatever you want in there that you want to appear in your posts
  • To put a picture in from your f150 online gallery, go to your gallery (in another window so you don't loose where your at)
  • Then go to the picture you want in the album and click on it so it appears big
  • then at the top right corner above the pic should appear in little red letters "forum codes"
  • click on that and another small window will appear
  • triple click on the text below where it says "fullsize image" and then hit CTRL + C
  • then go back to the page with the box to write your sig, and click there and hit CTRL+V
  • the image code should appear with [img][/img]
  • then click "submit modifications" at the bottom of the page and your set
  • then to make it appear when you post, in the screen where you write a post, at the bottom there are 4 boxes
  • click the one that says "show signature" and your done
It may take some messing around with to get it just right, but just post a message and edit it until you like your sig. Sorry if i made it sound like you were dumb or anything with the instructions, i don't mean it like that, but alot of new members usually have trouble figuring that out (i did) so they can all use this.
good luck. Next post from you i expect to see a sig!
