Removing Door panel
Old Jul 25, 2002 | 04:15 AM
808Hurley's Avatar
Removing Door panel
Does anyone know how to remove the door panel to gain access to the wiring?
Old Jul 25, 2002 | 09:10 AM
clonetek's Avatar
there are 2 screws holding the door panel on..
one is behind the "sail" panel. that is the panel right behind the window.
the other is behind the plastic "cup" that the door handle is in.
just pry the cup out & you"ll see the screw.
after that, pull up on the window & lock control panel & it will pop out for you to unplug.
then pull up on the door panel & it will slide off.
hope this helps...
brooks
Old Jul 25, 2002 | 06:13 PM
Harley#356's Avatar
hey, welcome to the site. post info on your truck when you get a chance
Old Jul 28, 2002 | 05:45 PM
808Hurley's Avatar
I'm gonna do some modification then post a pic . At the moment, my truck has the "fresh from the factory look".
Old Jul 28, 2002 | 05:46 PM
808Hurley's Avatar
Oh and thanks for the help
