steering wheel
steering wheel
I had a 2000 L before I purchased the 2002 H and really liked the steering wheel from the L much better.
Has anyone tried to replace the steering wheel, or does anyone know how to (with respect to the airbag?
Not sure what the 00 L steering wheel looked like, but the 00 HD wheel was the same as the 02's wheel, except for the 02 has the jeweled emblem, and the 00 just has the imprint. The 01's have the nicest wheel IMO cuz its 4 spokes instead of 2 like 00 and 01, and also has the jeweled emblem.
Ive got the ford service CD
Heres how the Dealers Ford Service CD say to remove it.
Wheel
Special Service Tool(s)
Remover, Differential Bearing
205-116 (T77F-4220-B1)
Removal and Installation
1. Turn the steering wheel to the straight-ahead position and turn the ignition switch to the OFF position.
2. Disconnect the battery ground cable (14301) and wait at least one minute to allow the depletion of the restraint system backup power supply.
3. WARNING:
To reduce the risk of serious personal injury, read and follow all warnings, cautions and notes in the deactivation procedure.
Deactivate the supplemental restraint system (SRS). For additional information, refer to «Supplemental Restraint System (SRS) Deactivation and Reactivation» in this section.
4. WARNING:
To avoid the risk of serious personal injury, read and follow all warnings, cautions, notes and instructions in the driver air bag removal and installation procedure.
Remove the driver air bag. For additional information, refer to «Section 501-20B».
µ 5. Remove the steering wheel bolt.
µ 6. CAUTION:
Removing the steering wheel without using a puller can damage the column bearings.
Use the 2-Jaw Puller to remove the steering wheel (3600).
7. Remove and discard the original steering wheel bolt.
8. Remove the steering wheel while routing the wires from the clockspring through the steering wheel.
9. To install, reverse the removal procedure.
10. WARNING:
To reduce the risk of serious personal injury, read and follow all warnings, cautions and notes in the reactivation procedure.
Reactivate the supplemental restraint system (SRS). For additional information, refer to «Supplemental Restraint System (SRS) Deactivation and Reactivation» in this section.
PICTURES WOULDNT POST
Wheel
3. WARNING:
4. WARNING:
µ 6. CAUTION:
10. WARNING:
Just noticed in some pics the 02 doesn't have the jeweled emblem. I saw a few pics before where it did.
Weird.
Anyway, yeah, Clonetek. I agree. The L wheel is alot nicer. Wonder why they don't put the same ones on the HD.
Weird. Anyway, yeah, Clonetek. I agree. The L wheel is alot nicer. Wonder why they don't put the same ones on the HD.
Moomba,
If youve got windows xp then I can email you a link to my desktop. You can then see whatever I have set up for remote users to see. If not I know theres other ways just have to figure them out.
