Mod mania...
Old May 19, 2002 | 03:44 PM
slingshot's Avatar
Mod mania...
OK... crunch time. Have the cash in hand--mods on the brain . Was pretty well set on waiting on the Autologic chip tuning from PSP--but no expected date of availability yet. Sooo--Finger is on the trigger to get the JLP 5 lb lower pulley (how much does this actually give our trucks? I've been told several different things ) with Diablo chip and 4x4 trans pan with valve body... question is, what about a cold air intake? Is it worth it? Or should I just add a K&N panel filter and mod the factory box? Does anyone have pics of JL's 'Twin Ram Air' setup?
Old May 19, 2002 | 06:57 PM
outnumbered's Avatar
Slingshot,
My buddy in Charlotte has the 5lb lower on his 02HD. Before the install, he had the exact amount of boost that I have--9lbs. After installing the pulley, he has 12.
All of the lower pulleys are rated with the L in mind (considering the smaller upper pulley). With that said, expect 2lbs less than what the lower pulley is rated at. So a 5lb pulley will net you 3lbs.
Old May 19, 2002 | 09:13 PM
slingshot's Avatar
Can you describe his twin ram air setup to me? I've called JLP about a dozen times over the past month--always get a voice mail (beginning to think these places are located in someones closet with PO box and an answering machine... ). I'm ready to put fear into the hearts of stock ls1's and Cobras, as well as embarass stock GT's .
Old May 20, 2002 | 10:47 PM
jonrauch's Avatar
friend in charlotte
outnumbered - if you dont mind id like to get in touch with your frind in charlotte to talk hand in hand with someone about modifications - i play for a minor league baseball team there and just bought my '02 hd and want to start workin on it.
thanks
jon rauch
2002 dsg hd
Old May 22, 2002 | 06:05 PM
2K1S10's Avatar
re
Jon, how do you like your HD? They're badass trucks IMO. I couldnt believe the power the first ride I took in one. What mods are out there for 02 HDs? My fiance's dad got one and may start modding soon. Which exhaust would be best? I was thinking dynomax ultra flo.
Jon, I saw you pitch on TV a while back. Youthrow some heat but I hope my BoSox win the pennant this year. Just playing with you. I hope the ChiSox win the central. You'll have some serious offense now.
