1/8, and 1/4 mile times
Not nearly as good as your L... combination of lo-pro 20" rims (means you have to idle off the line then punch it or go up in a cloud of smoke if you load it against the torque converter), 2 # less boost and 500 extra pounds of weight=mid 14's @ 96 or so in the quarter... maybe mid 9's in the eighth. Running in 85 degree weather with near 90% humidity and ****-poor air quality (density altitude near 5000 feet) last Friday I ran a 15.11 @ 93 mph--corrects to a 14.59 @ 97 at sea level. For comparison, a '01 L with chip'n filter (stock boost) ran a 14.1 at 99 in the same conditions... another one with chip/filter/5 lb lower pulley/exhaust/converter and ET Streets ran 13.30's at 104... With an anticipated increase to 12 lbs of boost (from the present 6-7), chip and filter--I hope to be running considerably quicker
soon. You sea level guys have it easy
