Need help with rear end
Old Jul 15, 2017 | 12:45 PM
Inez Silguero's Avatar
Truck used to burn out with both tires then suddenly burned out with one any info on what might be the problem
Old Jul 15, 2017 | 01:10 PM
MKTRUCK's Avatar
25 Year Member
I would check/change your differential fluid. Don't forget the additive.
You also may be in need of new clutch pack for the diff?
Old Jul 15, 2017 | 01:11 PM
Ok thanks will check that
Old Jul 15, 2017 | 09:40 PM
Roadie's Avatar
What is the axle code on the door sticker?
Old Jul 15, 2017 | 09:53 PM
Axle code is B6
Old Jul 15, 2017 | 09:56 PM
I would say your limited slip clutches are shot.
Old Jul 16, 2017 | 09:10 AM
Roadie's Avatar
If you try changing the diff fluid first, I would skip the additive since the clutch pack isn't holding now. You can add it later if needed.
Old Jul 22, 2017 | 10:37 PM
Veteran: Army
no, just no
if the friction modifier isn't in there, it'll kill the clutches if anything is left in there
