Follow Along as I Black-Out my 2006 HD
Old Jan 4, 2016 | 06:13 AM
  #61
07massHD's Avatar
Originally Posted by fords-rock
another tire question.
will 305/50r22's fit the stock wheels and not rub? leveling kit necessary to prevent rubbing. 34x12's...
also, i read a few people say a leveling kit on these AWD's HD's is not good for it. any comments?
Like I said I have had zero issues running the the 305's and I'm all stock. I have been running them for 4 years.
As far as leaving kits going more then 2 inches is where you run into problems. But I would search the form first.
If your going to run the nitto terra grapplers I would be carful aren't they real meaty,meaning don't they have big ***** on them. If so stay stock.
Old Jan 4, 2016 | 07:16 AM
  #62
fords-rock's Avatar
you said you ran 305/45s
i was wondering if the taller 305/50s would fit.
Old Jan 4, 2016 | 11:12 AM
  #63
fords-rock's Avatar
a little better shot of the ghost decals
Old Jan 4, 2016 | 04:05 PM
  #64
fords-rock's Avatar
some of the final plasti-dip has begun...
Old Jan 4, 2016 | 04:56 PM
  #65
07massHD's Avatar
Guess I miss read your post. 305/45 fit no problem. You will have to look/search around or google to see it that size will fit. Probably not.
305/50/20 I had on my old truck.
Old Jan 4, 2016 | 05:51 PM
  #66
fords-rock's Avatar
thanks, i will do some more research on those tires.
Old Jan 4, 2016 | 07:01 PM
  #67
fords-rock's Avatar
she is sure coming along nicely...
Old Jan 4, 2016 | 07:10 PM
  #68
fords-rock's Avatar
more...
just used the small led door sills that came in my kit. anyone want to buy the big sills?
Old Jan 5, 2016 | 12:06 AM
  #69
fords-rock's Avatar
just ordered some Bora 1.5" adapters...
should give the truck a more aggressive stance.
Old Jan 5, 2016 | 12:22 PM
  #70
fords-rock's Avatar
a picture of the finished trim work on the 2din radio... got my sub-woofer harness which is wired in stereo. radio only has 1 sub RCA jack. need to go back to the audio store and talk with the dude...
came out nice !!!!
sub-woofer up and running again !!!!
plan on ordering this to get the steering wheel controls working for it... uses IR remote function to learn from radio remote and then remotes from steering wheel to the radio...
http://www.pac-audio.com/productDeta...&CategoryID=29
Old Jan 5, 2016 | 12:27 PM
  #71
fords-rock's Avatar
now, a little bad news.
found the carpet wet on the passenger floor board while installing door sills.
after a little reading, it seems the most likely culprits are windshield, moon roof or 3rd brake light.
anyone have any recommendations for finding the origin of the leak?
Old Jan 5, 2016 | 07:08 PM
  #72
fords-rock's Avatar
Four KICKER DS68 coaxials on the way, 6x8's to replace the stock speakers...
and i am really digging what the wheels look like, they are just too small
got my LED light bar in. Hardware was a bit short so the install will be completed tomorrow.
Old Jan 5, 2016 | 07:49 PM
  #73
07massHD's Avatar
Not a fan of spacer at all. Make sure there of good quality and you torque them down right.
Wish I had a money tree like you do some where. I would be updating my truck like crazy!
Old Jan 5, 2016 | 07:57 PM
  #74
fords-rock's Avatar
yup, i bought hub and wheel centric BORA brand. some of the best you can buy. i went 1.5 inches to prevent any trimming of the studs since the back of the HD wheel is flat.
torqued to 150 lbs on the spacer and wheel will insure stability.
lol, not a money tree, just sold a house and am building new but down sizing so i got a few extra bucks to upgrade the truck
Old Jan 6, 2016 | 05:49 PM
  #75
fords-rock's Avatar
light bar mounted (not yet wired)
"FAKE" running boards removed and stored.
4" oval nerf bars installed...
