Time to go RACING!!
Old May 11, 2001 | 03:05 PM
devlishz's Avatar
Cool Time to go RACING!!
Hey...
After 2 tries, and 2 rainouts.. looks like tonight is the night the truck gets to prove it's self on the 1/4 mile.
Actually, it wasn't my intention to race the truck (much) but since my Camaro engine is still in pieces.. and the Club Challenge series has started.. well - the truck is it. It will give me a good "baseline" before I start the mods on it :-D
I'll let you know how it does - bone stock.. I heard that there was one out at another local track a couple weeks ago.. supposedly stock.. running 15.7s. That track is a bit faster than the one I'm running on tonight but here's hoping to 15s anyway.
The truly interresting part of all this is the 91 Camaro I will be racing (once it's back together with all it's new "go fast" mods) is actually not much faster; running mid 15s in it's stock configuration. So the truck is pretty impressive considering it outweighs the camaro by a good bit and still can run with it (and can beat most of those annoying ricers around too, however, for some reason they won't race me??)
Lanna
Old May 12, 2001 | 10:58 AM
RegularDave's Avatar
Post
Please post your results soon.I pan on doing some runs in mine too,to get some base #'s.I'm hoping to get a supercharger kit,soon as I convince my wife I really need one.
Old May 22, 2001 | 05:17 PM
devlishz's Avatar
Post
Well,
I was a bit dissappointed but here are the times..
16.17 first run of the day - cool weather.. rained out so didn't get any more runs.
16.24 First run of the day (1 week later) 71 degrees.
16.27 second run - 71 degrees
16:30 3rd run - 68 deg.. traction getting bad
16.32 4th run - 68 deg.. traction non existant
16.30 5th run (got beat)63 deg - no traction... spinning tires big time ;D
The track I was running at is known for it's "traction" issues.. they don't use the "sticky stuff" unless the NHRA guys are there.. about 2 hours into racing the traction is non existent... I had the same problems with my TransAm - running drag radials and waterbox burnouts..
The truck doesn't run very well when it's warm out - I was trying to spin the tires in the staging area but couldn't even get a good response from it till it got to about 68 deg and lower..I'd hit the gas but it would bog.. finally at 63 degrees I was able to spin the tires in staging, and had plenty of OOMPH off the line .. but no traction.
I was reviewing the time slips and it definately picked up speed when it was cooler out I just had no traction by that point.
I'm planning on running it out at the other local track for "all ford" day - should see some better times - 15.9s easily.. that track is usually up to 2/10s faster because they use the sticky stuff!
lanna
2000 HD F-150 - Planned mods: NOS system with chip, K&N Air setup, lower 3" front/back.
1985 Fiero GT
1991 Z28 Camaro - slightly modified!!
